AC Schnitzer sway bars and suspension components make the vehicle easier to control in all situations, and indicate the limit area to the driver as early as possible. The basic setting is sports-firm, but with maximum residual spring travel remains comfortable at all times and hence suitable for everyday use even for long-distance business drivers. With the upgraded sways you'll notice better handling at low and high speed. Keeping the amount of body roll to a minimum is mandatory for performance dirving. Larger sways will reduce the amount of understeer and bring it to more of a nutral position. The front is adjustable to suit to the needs of the driver or for quick setup changes for the track.
AC Schnitzer E46 M3 Series Anti-sway front is adjustable
$819.99
AC Schnitzer E46 Sedan 3 Series Anti-sway bars for 323, 325, 328
$819.99
**Sold as a pair front and rear.
$819.99
$819.99
