Hello to every bmw'er! Having electrical problems with my 1990 735il. When I drive at night the rear parking lights alternate from left or right or both being off. I have changed all the light bulbs out. I have no problem with the brake lights they work when I step on the brake pedal and also when i use the turn signals and hazards they work fine as well. This issue occures after 5 mins. after the headlight switch has been turned on. Also I can't Identify any of those square relays that are in the fuse box if any of those are faulty, I have checked all the little fuseses and all are ok. If any one knows a fix or a lableling of the relays I'd appreciate the info and help...........thanks.........
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
