You can also try turning every fan you see manually and see if anything is hitting it with the engine off of course and it wouldn't hurt taking the key out of the ignition. Check for the fan hitting the expansion tank (on mine it was a problem), you could try slightly moving the expansion tank by the cap while the engine fan is moving. Be very careful though.
Good luck, sorry I couldn't really pin point at anything.
