Outside temp sensor acting funky
28
Georgia
It is inside the front ground effect on the drives side, kind of below the drives side headlight.. Mine did the same thing but it took me some time to put 2 and 2 together.. I hit a piece of a retread in the interstate and then noticed later my temp was registering 122 degrees.. The I drive through some rain and it read - 39 degrees and the a/c wouldn't work.. What I found was the retread I hit jarred the wire loose and it was dragging the ground when it was dry, it registered 122+ when it was wet, it read - 39 apparently there is something in the system that tells the a/c compressor to not come on if it the outside temp is very cold.. I replaced the sensor and everything is fine.. Short story long- If I had to bet, I would say your sensor is bad...
