CARMEL, Calif., Aug. 13--So you say Chrysler's regular 340-hp 5.7-liter Hemi V8 in the 300C just isn't enough? It's too wimpy? Well, next spring you'll be able to get even more muscle--85 more hp and 30 more ft.-lb. of torque.
Chrysler unveils its cool new 300C SRT-8 sport sedan here today as part of the Pebble Beach Weekend. The SRT-8 takes the Chrysler 300 to the next level of performance with a bored 6.1-liter Hemi that's also had its compression ratio increased from 9.6:1 to 10.3:1. The result is a spleen-flattening 425-hp and 420 ft.-lb. of torque. And as you'd expect, the cylinder heads, and intake and exhaust systems have all been redesigned for increased flow. The SRT-8 exhales through two giant 3.5-in. exhaust tips. The high-performance 6.1 is backed by an A580 5-speed automatic that sends its juice to a beefed-up rear axle. As a package, Chrysler says the SRT-8 will catapult from 0 to 60 mph in a tick or two more than 5 sec., and through the 1/4-mile in the high 13-sec. bracket.
That would be enough for us to sign on the dotted line. But all Chrysler Group SRT products get more than just a beefy powertrain. Engineers tuned the chassis setup for good all-around handling. And that means high-performance dampers, spring rates and bushings, as well as larger antisway bars front and rear. The whole suspension system is lowered by a half-inch, which makes the car look even better on the road hunkered down over the massive 20-in. wheels and 45-series rubber. The ESP stability system has also been recalibrated for the SRT-8's more intense handling limits.
And to make sure the SRT-8 stops as well as it goes, Chrysler bolted a Brembo 4-piston brake caliper over each of the 14.2-in. front and 13.8-in. rear rotors.
You can get the SRT-8 in any color you want as long as it's silver or black. Check back after "The Weekend" for exclusive PM.Zone coverage of the entire 2004 Pebble Beach Concours d'Elegance.
What do you guys think?
