Put on your bibs!
Top Speed: 200MPH
Weight: 2,910lbs
P/W: 5.7lb/hp
0-60: 3.6 seconds
Chassis & Suspension development by Pratt & Miller, Aluminum Hydroformed frame produced by DANA- 345/30x19 Rear tires.
Brakes designed by Brembo:- 6 piston Front, 4 piston Rear Brake Calipers
- Cross Drilled (cast and camfered) Rotors
Engine Development by KaTech, To be hand built by new HP Engine Plant:
LS7 427ci/ 7.0L. 515HP/500 Ft Lbs
- 24V OHV
- Raced based CNC ported Aluminum Head with 70cc chambers
- 11.0:1 CR
- 41 mm (1.61") Titanium Intake valves
- 46 mm (1.81") Na filled Exhaust Valve
- 104.8 mm Bore (4.125") , 101.6 mm Stroke (4.0") Aluminum block
- Forgrd Crank
- Forged 6 bolt main Bearing Caps
- Titanium Rods
- Cast Aluminum Flat Top Pistons
- 0.591" Lift Cam (15 mm)
- Dry Sump
- 90 mm Throttle Body on Composite manifold
- Ram Air
Top Speed: 200MPH
Weight: 2,910lbs
P/W: 5.7lb/hp
0-60: 3.6 seconds
- 24V OHV
- 11.0:1 CR
- Forgrd Crank
- Titanium Rods
- Dry Sump
- Ram Air
