Clay bar question
493
Kapolei , Hawaii
Can a Clay bar put scratches on cars? I've used it many times with great results but my buddy mentioned that he sees scratches after i used the clay bar on his roof . His car had alot of trash in his paint so my question is...Can the particles that I get out with the clay bar scratch the surface when they're stuck in the clay .
And what the diff between clay bars...ie. fine, medium? Thanks alot .
Tom
Staff Team
8,351
13
Southwest
Yes it can if there are trapped debris in it. If it's new then you have nothing to worry about, just make sure you don't drop it. I spray the area down with Meguiars' auto detailing before rubbing it with the clay bar.
240
South
...With a good Quality lube mix...
Make sure the paint is properly washed before claying, keep an eye on the condition of the bar, turn frequently, all should be fine:)
493
Kapolei , Hawaii
You're right guys ,I do all of those things . It must be that after cleaning the clear coat now he can see all the imperfections.
Do I need more than one diferent clay bar in my detailing arsenal??
57
Oklahoma
Megs Quik Clay (grey) is a HUGE improvement over the last one that I tried. It did not fall apart and was actually pulling some contaminents out of the paint. I would say it performed as well as my measuring stick which is the Mother's clay.
Now for Megs new agressive clay the C-2100 is GREAT CLAY!!! Here is how I judged it. After claying the car with Quik Clay (BTW, I used it with both soapy water and QD and it performed the same), the paint still felt a little rough. So I brought out the Mother's clay and re-did the hood, roof and back lid to see if the Mother's would smooth things out better. It didn't. In addition, using the Mother's clay I began working on a spot that had another color on it, like the car had been run into by an red/orange car or some other object. Neither the Quik Clay or the Mother's clay would get the foreign paint off. I thought this would be the perfect time to test the "New" aggresive clay the C-2100.
I began to rub the new clay on the foreign paint and it started coming off I than began re-claying the top half of the car. The strange thing about the roughness of the car was that I could not see the contaminents, only feel them. After claying with the C-2100 the paint was smooooth. I felt the clay and I could feel the bumps on the clay but again, I could not see them.
I don't know how clay compare to each other in terms of aggressiveness but I did find that there can be a big difference.
6,984
New Jersey
How often should we clay bar our cars? I have the Zaino Z-18 Clay Bar and Zaino told me I should clay bar my car every 18-24 months, depending on conditions.
240
South
#10
Clay-
Used for "pulling" contaminants "out" of the paint...,
Picture it like this-
The paint has "splinters-
Clay is the tweezers....
Your paint will be much healthier, the shine will last longer, polishing and waxing will be easier, the finish will be smoother, lots of good benifits:)
