1998 740il... Seems to be a leak from the point where the resovoir/expansion tank is attached to the radiator shroud. There is a large threaded plastic (okay, maybe it's nylon...) bolt which holds two semi-circular pieces together which seem to act as a connector for the expansion tank and shroud. This bolt has a rectangular verticle slot in it. It seems that after the car has warmed up and been driven foir a while, that it leaks from this point. Is there a trick to the alignment of this bolt or what? [headbang]
