Passenger Side Rear Door Trim
202
VA
My passenger side rear door trim clips of my '03 325XI that hold the trim to the car peeled off.
I think it is just applying a glue to it, but I concern if there is a particular way the plastic clips should be mounted and if there is a special glue I should use.
Bentley Service Manual doesn't mention anything about this trim/clip. Trim.jpg
Has any one experienced this problem?
Thanks!
Zman
I have zero experience with this, but would recommend you contact the dealer about the adhesive as I am sure it is something specific, either that or they are peel and stick? I have no idea which way the clips go either. Remember to clean the surface area where the clips mount with an alcohol pad before applying.
